Creating a Smart Preflight Variable Set
Once in the Enfocus Variable Set Editor, you can name your Variable Set.
In the SETUP > General section, enter a name for the Variable Set in the Name textbox.
You can optionally enter a brief description about the Variable Set in the Description multi-line textbox.
You can set a layer of security to your Variable Sets by locking them using a password to disable editing. In the Permissions drop-down menu, select the Locked option to set a password to protect your variable set. The Change Password... dialog box appears. Enter a password in the Password textbox. Enter the same password in the Confirm password textbox and click OK button. Click Save button in the Enfocus Variable Set Editor.
A locked Variable Set can be used anywhere like a normal Variable Set. By locking a Variable Set you are only preventing other users from editing the Variable Set and viewing complete details when they open it in the Enfocus Variable Set Editor.
Whenever you open such locked variable sets, you'll have to enable editing by providing the specific password to remove the lock.
You also have an option to change your password at any point of time. Click the Change Password... button, enter a new password in the dialog box which appears and click OK button and Save button in the Enfocus Variable Set Editor.
Whenever you wish to remove the lock from a Variable Set, open the Variable Set, click this icon in the Enfocus Variable Set Editor to open the Enter Password... dialog box. Enter the password to unlock it and enable editing. Now, select the Not Locked option in the Permissions drop-down menu and click Save button in the Enfocus Variable Set Editor.
When you try to export a Variable Set which is not locked, the following dialog box appears warning that the Variable Set is not protected with a password.
If you want to export the Variable Set without locking it, click OK button. If you do not want to see this warning again select the Don't show this message again check box before you click the OK button.
To add a new variable to a new or existing list, click the button in the lower left of the dialog box. Click the button to remove a variable from the list and click the button to duplicate a selected variable.
Click this button to test or verify current variables.
After you create a new variable by clicking the + button, you can name it by typing a name in the Name textbox.
Note: Be sure to name the variable something easily recognizable, for example, the check it is intended for.
You can optionally enter a brief description about the variable in the Description multi-line textbox.
Different types of variables
As described earlier in this chapter, there are two different types of variables that can be created - "Constant" and "Rule Based".  Each type of variable needs to have a variable "Type" defined. It is important that the variable type matches the preflight check setting it's intended for. When applying variables to a preflight check setting, only the variables which match that type of entry will be displayed.
For example, if a variable for a trim page size is to be created, then it must have a "Length" variable type. If a variable is needed to select or deselect a check box (such as to turn on a correction), then a Boolean variable type needs to be defined.
Variable Type:
Type Description Example Use
Number A whole number Page count, Number of separations, etc
Length A number Page trim size, bleed amount, etc
String Any text Document Author, Font Name, Spot Color name
Boolean On or off Turn Checks or Fixes on or off at runtime
