A Variable Set contains all your Smart Preflight variables that can be used within your
Preflight Profiles. You can create more than one Variable Set and each set can have multiple
variables defined. However, you can only run one "active" Variable Set at a time within
PitStop Pro. It is recommended that you keep all your variables within one Variable Set unless
you are also working with PitStop Server.
Note: If you use variables that are contained in
different Variable Sets within a single Preflight Profile, only the "active" Variable Set
variables will contain their default values. Variables used from inactive Variable Sets will
be blank.
To create a Variable Set,
- In Acrobat X, click on the Tools and navigate to PitStop
Process and the Smart Preflight option. In the
drop-down menu, select Variable Set Preferences to display the
Enfocus PitStop Pro Preferences and the Variable Sets available.
Or navigate to to display the Enfocus PitStop Pro Preferences and
- In older versions of Acrobat, navigate to to display the Enfocus PitStop Pro Preferences and
Note: You can also go to the Acrobat
menu and About Third Party Plug-ins to access the
PitStop Pro Preferences on Mac OS.
- With the Enfocus PitStop Pro Preferences open, select the
Manage... (
) drop-down menu and New
from the sub-menus. This will create and open a new Variable Set that will be saved to
your "Local" PitStop Pro folder.
