Preferences > Enfocus PitStop Pro Preferences > Licensing
Provide the IP address of the license server to get floating licenses:
  1. Enter the address of the PitStop Workgroup Manager in the Address textbox.
    Note: The IP address of the license server can be found in the status bar of Workgroup Manager. You can select it, and copy-paste it into the Address textbox.
  2. Indicate which port number should be used:
    • To use the default port, make sure the Use Default Port checkbox is enabled.
    • To use another port, clear the Use Default Port checkbox and enter the appropriate port number.
  3. Restart PitStop Pro.
