Overview
Using Smart Preflight within
PitStop Pro is simple. Following is
the overview of the step to using Smart Preflight variables within
PitStop Pro.
- Create a Variable Set
- Define the variables to be used
- Apply (activate) your Variable Set
- Edit a Preflight Profile and locate a check to use a variable
- Enable Variable Names under the "Action" for that preflight check
- Select the correct variable for that check
- Save your changes
- Run the Preflight Profile with variables defined
The following sections will go into more detail about each step.
