The Action Lists dialog
The Action Lists dialog allows you to organize, access and run Action Lists:
The Action Lists dialog consists of the following screen parts:
# Description
1 Buttons to switch between Action Lists () and other "presets" (Preflight Profiles , Global Changes and QuickRuns ).
2 A search field (allowing you to search for a particular Action List) and an Action menu (allowing you to organize the Action Lists).
3 A workspace, which displays the available Action Lists. The Action Lists are organized in folders, called "databases". By default, the following folders can be found:
  • Favorites: Action Lists marked as your favorites. This provides you fast access to the Action Lists you need often.
  • Recent: The 10 most recently used Action Lists.
  • Standard: The default Action Lists installed with PitStop Pro (grouped in subfolders, such as Color, Fonts, Image,...).
    Tip: To learn what an Action List can do, double-click it, and check the content (the Actions it contains) and the description.
  • Local: Action Lists edited and created by you, and saved locally.
4
The bottom part of the dialog allows you to run the Action List selected in the upper part of the dialog.You must indicate on which page(s) the Action List should run and whether or not the results should be shown in The Enfocus Navigator.
