To rotate an object using the Rotate Selection tool
In the Enfocus Inspector dialog, click the
Select Objects
tool
Select the object(s) you want to rotate.
Click the Rotate Selection
tool
The Enfocus Inspector changes accordingly.
If necessary, change the Constrain Angle (for
SHIFT-rotate) or
the Cross Hair Color
in the Enfocus Inspector. You can change the Cross Hair Color by clicking
the color patch and selecting a different color.
Note: In the Numeric Feedback area you can find exact
information about the rotating action you are about to perform.
Click the selected object.
The object’s point of origin around which it will be
rotated is indicated.
Figure 1. The point of origin is in the center of the
selected object.
Do one of the following:
- To rotate the object around its center point, drag
the selected object in a circular motion.
Figure 2. Rotating an object around its center
point.
- Double-click on another position to move the point
of origin. Move the pointer away from the center point and drag in a
circular motion to rotate the object around its new point of
origin.
Figure 3. Rotating an object around its point of origin
placed outside the object.
- Hold down the SHIFT key while
dragging to rotate the object in fixed angles. You can set this angle in
the Numeric Feedback category of the Enfocus Inspector dialog box.
- Hold down the ALT key (Windows) or
Option key
(Macintosh) while dragging to create a rotated copy of the selected
object.
