To replace an object
  1. Using the Select Objects tool , select the “new” object, i.e. the object which you want to use to replace with the other one.
  2. Choose Edit > Copy .
  3. Select the “old” object, i.e. the object which is to be replaced.
  4. Choose Edit > Replace .
    The copied object will replace the “old” object and will assume its exact size, proportions and position.
