To start a Certified PDF workflow
  1. Open the PDF document for which you want to start a Certified PDF workflow.
  2. Choose Certified PDF > Start Edit Log, or click the Start Edit Log button in the Enfocus Certified PDF Panel
    Note: If you have made any changes to your PDF document, you should save it before you start the Certified PDF workflow. If you did not save it, a warning will appear prompting you to do so.
    The Certified PDF workflow has now been started for this PDF document.
  3. Click OK.
