Primary and secondary highlight color
Using the Edit Log of Certified PDF documents, you can view the changes in your Certified PDF document highlighted:
  1. Specific change of an active editing session in the primary highlight color
  2. Other changes on the page in the secondary highlight color
Proceed as follows to change the primary or secondary highlight color:
  1. Click a color patch.
  2. Click anywhere in the color wheel.
  3. If necessary, drag the sliders at the right of the color wheel to change the Hue, Saturation or Brightness of the color.
  4. Once you have defined the color you want, click OK.
