Adding Action Lists to a Preflight Profile
Before you perform a preflight check, you may want to edit your PDF document first, for example run a number of Action Lists to correct or change colors. Instead of running these Action Lists separately and then performing the preflight check, you can include them in your Preflight Profile. You will then kill two birds with one stone:
To add Action Lists to a Preflight Profile
  1. Open the Preflight Profiles dialog box. See To open the Preflight Profiles dialog box.
  2. Double-click the Preflight Profile you want to change.
  3. In the The Enfocus Preflight Profile Editor, under EXTRA (left pane, last section), select the checkbox next to the Action Lists category. In the upper part of the dialog, you can add Action Lists containing "Change" Actions only, whereas in the lower part, you can add Action Lists containing "Check" Actions only.
  4. Add the appropriate Action Lists:
    1. Click .
    2. Select the appropriate Action List.
    3. Click OK.
    4. Repeat the previous steps for each Action List you want to add.
  5. You can edit the added Action Lists and modify them to suit your needs.
    1. Select the Action List you want to modify.
    2. Click the Edit Action List button.
    3. In the Enfocus Action List Editor dialog box, make the required changes. See To create or edit an Action List.
    4. Click OK.
    • You are editing a copy of the Action List that exists within the Preflight Profile. You are not changing the version within the Action List Database!
  6. If you add several Action Lists, use the and buttons to specify the order in which the Action Lists should be run.
    Note:
    • Running two or more Action Lists in a different order may produce a different result. You may want to test this first.
    • You can export an Action List, for example after you have edited it. To do so, select the Action List concerned and click the Export Action List button.
    By default, the added Action Lists are turned on, meaning that they are always executed when the Profile is run. You can manually turn off an Action List (if you don't need it), by clearing the On/Off checkbox in the Preflight Profile. In that case, it will not be used.
    Alternatively, you can enable Action lists based on a variable. This means that the value of the variable determines whether or not the Action List is executed when running the preflight check (see next step). See Smart Preflight for more information on Variable Sets and Smart Preflight.
  7. To use variables to enable or disable the Action Lists within a Preflight Profile:
    1. Click the Actions menu at the top right corner of the dialog box.
    2. Click Enable Variable Names. The variable button appears between the On/Off checkbox and the name of the Action Lists.
    3. Click next to the Action List for which you want to use a variable.
    4. Select a Variable set (if the default one is not the desired one), a variable, and click OK. The Variable's User Readable Name is displayed within the square brackets of the variable button.
    If you don't want to use variables for all Action Lists, leave the variable button as it is. The state of the On/Off checkbox determines whether or not the Action List will be executed.
  8. To save your changes to the Preflight Profile, click OK.
