Locking a Preflight Profile with a password
You can secure your Preflight Profile, or part of it, with a password to prevent others from changing its settings. This may be convenient when the Preflight Profile is shared among multiple users. You can lock a Preflight Profile with a password when you create the Preflight Profile or you can add a password afterwards.
  1. Open the Preflight Profiles dialog box. See To open the Preflight Profiles dialog box.
  2. Double-click the Preflight Profile you want to change.
  3. In the Enfocus Preflight Profile Editor, under SETUP (in the left pane) select General and navigate to the Permissions category.
  4. Select a permission level in the Profile is drop-down menu:
    Restriction level Meaning
    Not locked None of the settings of the Preflight Profile will be locked. Anyone can change any setting.
    Partially locked Everything is locked, except for the actions you allow using the options underneath the list:
    • Allow changing 'Allow fixes' (under Problem Handling)
    • Allow changing 'Allow sign-off' (under Problem Handling)
    • Allow changing 'Log fixes' (under Problem Handling), 'Preflight Report' (i.e. options under Preflight Report) and 'Color management' settings (options not under General, but under SETUP - Color Management).
    Locked Nothing can be changed. Users can only select the Preflight Profile and run it in their PDF document.
  5. If you have decided to set a password, click Set Password.
  6. Enter a password and confirm it.
    The password can include:
    • Uppercase and lowercase letters
    • Any character on the keyboard
    • Spaces
  7. Click OK.
  8. To save the Preflight Profile, click OK.
