Sign-off
If a property is set to Sign-off in the Preflight Profile, the deviating property will result in an error in the report. However, you can decide that the error is not a real problem for the job or workflow. Such a property will then be handled as a warning.
  1. In the Enfocus Navigator, open the Sign-off section by clicking the + button
  2. You might enter a note on why you sign off the error
  3. Do one of the following:
    • Set the Apply to option to all problem objects to sign off all problems at once.
    • Set the Apply to option to current object, and use the Object Browser to select the specific object and error you want to sign off.
  4. Click the Sign Off button
