Applying a workspace means using it for your current work. Next time you open
Acrobat, you'll have to apply it again (if required), unless you set it as your startup
workspace.
To apply a workspace
Open the Enfocus
Workspace Panel and click the Apply button.
In your toolbar (Acrobat 8 and 9) or the Tools pane - PitStop View
panel (Acrobat X and XI), click the arrow beside the Enfocus Workspace button
and select .
Alternatively, in Acrobat 8 and 9, you can select the workspace
you want to apply in the menu.
A message may appear, asking you to make a number of settings manually. For example,
if in the workspace overprint settings are enabled, you will be guided to the Page
Display category of the Adobe Preferences dialog. You can then manually make the
required change.
