Example: To apply a radial gradient to a line-art object
This example creates a rectangle and applies a radial gradient fill to it (in RGB colors).
Step Action Result
1 Create a rectangle.
Location in Acrobat 8 or 9:
Enfocus Editing Tools toolbar:
Location in Acrobat X or XI:
Tools pane: PitStop Edit >
2 Apply a solid fill.
Enfocus Inspector dialog box:
3 Apply a gradient fill.
4 Display the control bar on the PDF document.
5 Change the gradient type to radial.
> > Type
6 Reposition the control points of the control bar on the PDF document and adjust the circles.
7 Change the color gradient fill using the control bar in the Enfocus Inspector dialog box:
  • Add color control points by clicking at the bottom of the bar.
  • Remove color control points by dragging them away from the control bar, or by selecting them and pressing the Delete key.
  • Change the color by double-clicking color control points.
  • Change the position of color control points and midpoints by dragging them along the control bar (or by changing the Location option for a selected control point).
