Setting a trim box relative to a selection
To set a trim box relative to a selection
  1. Select one or more objects, using the PitStop Select Objects tool .
  2. Select the (Enfocus) Set Trim Box menu item. The table below indicates where you can find it.
    Adobe Acrobat version Menu option
    Adobe Acrobat 8 and 9
    Plug-ins > Enfocus PitStop Pro > Set Trim Box OR
    Edit > Enfocus Set Trim Box
    Adobe Acrobat X and XI PitStop Pro > Object > Set Trim Box
    The trim box is set with the margins defined in the Trim Box Margins Preference.
