You can undo any unsaved actions which you have done with one of the
PitStop Pro tools. An “action”
can mean changing something but also selecting one or more objects.
To undo your actions, you have two buttons in the PitStop Pro panel:
| Button |
Undoes |
Usage |
Changes only.
In situations where you have done multiple changes
and maybe made some selections in between.
For example: select text, move it on the page,
change the font and color. Select an image, scale it and place it
below the text.
Changes and selections.
In situations where you have made a lot of
selections, and sometimes even very complex ones, for example using the Enfocus wireframe view
Or when you were selecting a lot of objects and you lost your
selection due to a “slip of the mouse”.
After undoing one or more actions, you can redo them again, using
Redo and
Redo
Selection.
Note: If you are working with Certified PDF documents, you can even
undo actions after you have saved the file.
