Preferences > Enfocus PitStop Pro Preferences > Variable Sets
A variable is a special, well-recognizable string that gets replaced by a dynamic value. Variable data can be used to provide a value for a property.
Variable sets in PitStop Pro help you to change the parameters of the Preflight Check and Action List at runtime. It allows data from sources such as manual entry to be used.
You can define the default Variable Set for processing in PitStop Pro in Enfocus PitStop Pro Preferences > Variable Sets .
