| Color space | Object type | Overprint mode | Rule |
Separation DeviceN |
Irrelevant |
Irrelevant |
Only those inks are specified as listed in the respective color space. Separation Black, for example, will only have the black ink specified, not cyan, magenta or yellow. |
Gray RGB Lab ICC-based colors Calibrated Gray or RGB |
Irrelevant |
Irrelevant |
Cyan, magenta, yellow and black inks are specified. To determine the percentage of the inks in non-CMYK objects, the colors in these objects are converted to CMYK according to the normal color conversion rules. An object in Gray, for example, may have the following inks specified: C: 0 % M: 0 % Y: 0 % K: 60 % Consequently, objects in Gray will always knock out the underlying cyan, magenta or yellow, regardless of the object type or overprint mode. |
CMYK |
Image Shading |
Irrelevant |
Text Line art Image masks |
Standard (OPM 0) |
Illustrator (OPM 1) |
Only those inks are specified of which the tint value is not equal to zero. |
We learn the following from this overview:
