If problems (warnings, errors) are reported, you may want to solve them.
- In some cases, you will find a solution in the Enfocus Navigator. You can use this
fix for all problem instances in the file, or you can browse to a particular object and only
fix that one. Note that it may be handy to use the PitStop Inspector to learn more about the
problem concerned.
- If no solution is recommended, you can generate a Report (see Generating a Report) and click the information icon
to find a
solution for the problem concerned. In many cases, you can just run another Action List to fix
the problem. For example:
- Layer problems found with the "Check layers" Action can be solved with the "Fix layers"
Action.
- Font problems found with "Check corrupt font widths" can be solved with "Change corrupt
font width", ...
