Applies a different amount of brightness to each input brightness value.
Enfocus Inspector dialog box:
The amount of output brightness is represented by a curve that you can edit.
You can perform this on:
- A separation (channel) of an image. Example: The red channel of an RGB
image.
- A complete image.
- Multiple images that have the same color space.
Tip: Curve editing is not available in the Action List editor, but you
can record it as an action, and then use it in an Action List.
