Using the Select Objects
tool
select the object which you want to shear. Click the object or drag a rectangle,
called a marquee, around the object.
Example: Dragging a dotted rectangle around the object to select the
entire graphic.
Click the Shear Selection tool
The object’s point of origin from which it will be sheared
is indicated.
The point of origin is in the center of the
selected object.
The Enfocus Inspector changes accordingly.
If necessary, change the Constraint Angle (for
SHIFT-shear) or
the Cross Hair Color
in the Numeric
feedback area of the Enfocus Inspector.
Note: In the Numeric Feedback area you can find exact
information about the shearing action you are about to perform.
Do one of the following:
- To shear the object while keeping the center point
as the point of origin, drag the object into a random direction.
- To move the point of origin, double-click on another
position inside or outside the object. Then drag to shear the object
using the object’s new point of origin. For example, to create a
parallelogram from a rectangular object, place the point of origin on
any of the corners of the object.
Example: Placing the point of origin on the corners of an object to
create a parallelogram from a rectangular object.
- Hold down the SHIFT key while
dragging to limit the shear movement to a fixed angle of constraint, for
example 15°. You can set this angle in the Numeric Feedback category of
Example: Shearing an object in fixed angles, as defined
in the Preferences.
- Hold down the ALT key (Windows) or
Option key
(Macintosh) while dragging to shear a copy of the selected object.
