To scale an object by dragging
Choose or click the Show
Inspector button
to display the Enfocus Inspector.
Using the Select Objects
tool
select the object that you want to scale. Click the object or drag a rectangle,
called a marquee, around the object.
The following image shows how dragging a marquee around the object allows you to select
the entire graphic.
Click the Scale Selection tool
The Enfocus Inspector changes accordingly.
If necessary, change the Cross Hair Color in the
Enfocus Inspector.
Note: In the Numeric Feedback area you can find exact
information about the scaling action you are about to perform.
Click the selected object.
The object’s point of origin towards which it will be
scaled is indicated.
The point of origin is in the center of the
selected object.
Do one of the following:
- To scale the object disproportionally, drag the
selected object into a random direction.
Example: Scaling an object disproportionally changes
the height-to-width ratio of the object.
- Double-click on another position of the object to
move the point of origin. Then drag to scale the object using the
object’s new point of origin. For example, you may want to place the
point of origin on one of the corners of a rectangular object, to keep
two sides of the object at a fixed position when scaling.
Example: Scaling an object towards a point of origin
other than the object’s center point.
- Hold down the SHIFT key while
dragging to scale the object proportionally, i.e., to keep the
height-to-width ratio of the scaled object identical to the
original’s.
- Hold down the ALT key (Windows) or
Option key
(Macintosh) while dragging to create a scaled copy of the selected
object.
