To change or remove the OPI information of objects
Using the Select Objects tool
select an object in your PDF document for which you want to change the OPI
information.
Choose or click the Show
Inspector button
to display the Enfocus Inspector.
Click Prepress > OPI to display
the OPI information of the selected object.
Do one of the following:
- To change the OPI information, put your cursor in
the File name
box, make the required changes and click Change. For example,
you may wish to change the file name or path of the image.
- Select Remove OPI Information from the
Actions drop-down menu.
