In the Guides category of the Design Layout Editor, you can define the guides you need.
To define the guides in your Design Layout
A new line is added to the table under Settings.
| Setting | Description |
| Color and Name | Representation color and name for the guide. Note: These
values can be changed by double-clicking them in the
table.
| Orientation | Vertical or Horizontal. |
| Relative to | Page box used as reference, or another guide. |
| Anchor Point | Reference point on the page box. Top/Center/Bottom for Horizontal guides, Left/Center/Right for Vertical guides. |
| Guide Name | If Relative
to is set to "Other Guide", you can select a
guide from the drop-down. Only guides with the same orientation
will be available. Moving a guide will also move the guide(s)
that are "Relative to" this guide. Note: If
the "Relative to" guide is removed, the depending guide’s
settings will change to Relative to Media
box.
| Offset | Distance from the reference point. A positive value is to the top/right, a negative value to the bottom/left. |
| Mirror for even pages | (Only for vertical guides): mirror the guide horizontally over the center line of the crop box on even pages. |
