Choose Window
> Show Enfocus
Inspector or click the Show
Inspector button
to display the Enfocus Inspector.
Click the Fill and Stroke
> Transparency category.
Select the object of which you want to change the
transparency.
Do any of the following:
To change the transparency, move the Alpha Stroke or
Alpha Fill slider.
If you make text transparent, you may want
to select the Text
knockout option. The inks of underlying objects, if any,
will then be cut out on the other separations.
This option may be
useful in case of overlapping characters, as shown in the table
below.
Text Knockout
Example
disabled
enabled
To change the way in which the colors of the
transparent object on top blend with the colors of underlying objects,
add the required blending modes. Select one or more blending modes in
the Available
list and click the Add or Replace button to put them in the Selected list. The
RIP will apply the blending modes in the order as they appear in the
Selected
list: If it cannot apply the blending mode which is on top of the list,
it will try to apply the second one, and so on.
Note: For more information about blending modes, visit the
Adobe Web site (www.adobe.com) or refer to
the Help or documentation of your design application (Adobe InDesign,
QuarkXPress,...).
