Starting a Certified PDF workflow for a PDF document means that you ‘stamp’ the document: You provide it with the information necessary to enjoy the benefits of the Certified PDF workflow for that particular PDF document. As soon as you have started a Certified PDF workflow for a document, any change made to the document will be “recorded” per editing session and can be traced in the Edit Log.
To start a Certified PDF workflow
. This will open the Enfocus Certified PDF
Panel. Next, click the Start
Edit Log button.The Certified PDF workflow has now been started for this PDF document.
Preflighting is optional. You can as well only use Certified PDF to keep track of changes made in the PDF.
to close the Enfocus Certified PDF Panel.
