Viewing the document history
The Certified PDF mechanism in PitStop Pro allows you to consult the history of your PDF document. This means that you can view a chronological list of all the sessions that your Certified PDF document has run through.
The chronological list of sessions contains the following information:
To view the document history
  1. Choose Certified PDF > History .
  2. Double-click any of the sessions to see all available details about that session.
  3. Click the User or System tab to view the corresponding information for this particular session.
  4. To compare versions (i.e. the state of the documents at the end of the selected session), select two sessions (holding down the Ctrl key) and select the option of your choice. Refer to Comparing sessions.
  5. To save a snapshot of a version (i.e. the state of the documents at the end of the selected session), select the session concerned and click the Save Snapshot button. Refer to Saving a snapshot of your PDF.
  6. Click Close.
