Changing the rendering intent of an image
To change the rendering intent of an image
  1. Using the Select Objects tool , select a pixel image.
  2. In the PitStop Inspect panel (under Tools), click the Show Inspector button .
  3. Click the Fill and Stroke > Fill category.
  4. Select a Color rendering intent.
  5. If necessary, adjust the Smoothness.
    Note:
    • The smoothness tolerance controls the quality of smooth shading and thus indirectly controls the rendering performance.
    • Smoothness is the allowable color error between a shading approximated by piecewise linear interpolation and the true value of a (possibly nonlinear) shading function. The error is measured for each color component, and the maximum error is used.
