To change the overprint settings of an object
  1. Make sure overprint previewing is on in Adobe Acrobat (Advanced > Overprint Preview).
  2. Using the Select Objects tool , select an object.
  3. Choose Window > Show Enfocus Inspector or click the Show Inspector button to display the Enfocus Inspector.
  4. Select the Fill and Stroke > Overprint category.
  5. Change the Fill or Stroke overprint settings.
    • = on
    • = off
  6. If necessary, select an Overprint Mode: OPM 0 or OPM 1.
    Note: You will only see a difference between the overprint modes if you turned the Adobe Acrobat overprint previewing on, as described in step To change the overprint settings of an object.
