To convert text to outlines
  1. Using the Select Objects or Select Similar Objects tool, select text in your PDF document.
  2. Choose Window > Show Enfocus Inspector or click the Show Inspector button to display the Enfocus Inspector.
  3. Click the Text category.
  4. Select Convert text to outline in the Actions drop-down menu.
    Note: You can also use a Global Change or Action List to convert all the text in your PDF document to outlines.
