Adding PitStop Pro panels to the Tools pane in Acrobat 2015 or Acrobat DC
The Enfocus PitStop Pro panels are not shown by default. You have to add them manually to the Tools pane, in order to be able to use the PitStop Pro tools.
To add the PitStop Pro panels
  1. Open Adobe Acrobat.
  2. In the toolbar at the top of the application, click Tools.
  3. In the search field below, type PitStop and click the search icon . The PitStop Pro panels are listed.
  4. From the list below the PitStop Pro panel you want to add to the Tools pane, select Add. The added PitStop Pro panel appears in the Tools pane (at the right).
  5. Do this for all PitStop Pro panels. To add the Certified PDF panel as well, type Certified PDF in the search field (step 3) and click Add in the list below the search result.
  6. To access the tools included in the PitStop Pro panels, do one of the following:
    • Click the name of the PitStop Pro panel concerned.
    • Right-click the name of the PitStop Pro panel concerned and click Open.
    • In the Acrobat menu bar, click View > Tools > <name of the PitStop Pro Panel concerned> > Open .
    • If another panel has been opened already, click the small arrow below the name of the panel and select the PitStop Pro panel you want to open (see screenshot below).
    The tools are shown at the top of the document or at the right side (PitStop Edit panel).
    Note: If there is not enough room to display all tools, you will see the following icon: ; simply click this icon to see the missing tools.
