Applying a shortcut set
Before you can use the shortcuts defined in a particular set, you must apply the shortcut set.
To apply a shortcut set
  1. Go to Edit > Preferences (Windows OS) or Acrobat > Preferences (Mac OS) and select Enfocus PitStop Pro Preferences.
  2. In the Category field, click Shortcuts. In the Shortcuts pane, all available shortcut sets are shown. The shortcut set that is active is shown in the Currently applied section.
  3. Select the shortcut set you want to use in the application.
  4. Click Apply. The selected shortcut set is shown in the Currently applied section. The shortcuts defined in the new set can be used immediately. The shortcuts are displayed in the menus as well.
