Before you can use the Monotype Baseline platform, you have to set it up.
To set up the Monotype Baseline platform
Example: If your PDF document contains three missing fonts and PitStop Pro finds one on your local system, you need two tokens to retrieve the other two from the Monotype Baseline platform.
