| To modify an existing shortcut or to add a new one |
1. Select the menu command in the upper part of the pane.2. In
the Edit Shortcut section, configure the new
shortcut:
On Windows:
Click the Alt+,
Shift+ and/or the
Ctrl+ button as required. The
selected buttons are highlighted in blue.
To remove a modifier key from your shortcut, click the
Alt+,
Shift+ and/or the
Ctrl+ once more, until it is
no longer highlighted.
On Mac OS:
Click the +, +
and/or the +
button as required. The selected buttons are highlighted
in blue.
and/or the +
button once more, until it is no longer highlighted.
- In the last field, type a character. Only uppercase
characters are allowed.
The new shortcut combination is shown in the list.
| To delete an existing shortcut |
1. Select the menu command in the upper part of the pane. 2. Click
the Delete shortcut button.
| To restore the default Enfocus PitStop Pro shortcuts |
1. Click the Reset all shortcuts
button. The default shortcuts are shown in the list.
