To find and replace text:
Do one of the following:
- Choose .
- In the PitStop Edit panel (under Tools) click
In the Find And Replace Text dialog box, type the text
you want to search in the Find textbox.
Select the appropriate options:
- Case sensitive if you want to find the exact word
that you type (i.e., upper case or lower case).
- Current page only to restrict your search to the
current page of focus only.
- Select partial text objects if your search query
is only a part of a whole word.
To check all found (and highlighted) instances of the search term one by one,
click Next (to start from the current page), or
Previous (to go back to the beginning of the
document).
To replace the search term with another word of your choice
Type the word in the Replace textbox.
Click Replace to replace a search term which has
already been highlighted, or Find & Replace
to replace the currently highlighted search term and find the next
instance of it.
