Use this task to manually check for missing fonts in your PDF document on a
case-per-case basis. You can then embed the missing system fonts (if any), and decide
whether or not to buy the other missing fonts from Monotype.
In the menu bar, click .
If you have set up the Monotype Baseline platform, PitStop Pro will immediately
start checking the document for missing fonts. Proceed with step 3 of this
procedure.
If you haven't set up the Monotype Baseline platform, a dialog
pops up. Proceed with the next step.
In the Configure Monotype Baseline Account dialog, do one
of the following:
- If you only want to check if the missing fonts are available on your
local system, click Continue without
Registration.
- If you also want to check if the missing fonts are available in the
Monotype Baseline platform:
- Click the appropriate link (Register for an online
account or Retrieve your Authentication
Key here).
- Follow the on-screen instructions.
- Enter your authentication code in the Authentication
Key field.
- Click Continue.
PitStop Pro:
- Checks the PDF document for missing fonts.
- If any, looks for them firstly on your local system.
- If not found, and if you have entered a valid security token, looks
for them in the Monotype Baseline platform.
- If any fonts are missing, opens the Fix Missing
Fonts dialog.
If the Fix Missing Fonts dialog opens:
- Locate the missing fonts and preview how your document would look with
the missing fonts embedded.
- Decide whether you want to buy the missing fonts from Monotype Imaging
Inc.
- To only embed the missing fonts that are available on your local system
(listed in the Available on system (free) section),
click Fix Fonts From System (Free). This is a free
service.
- To embed the missing fonts that are available for download from the
Monotype platform (listed in the Available for download
section), click Fix All Fonts.
- To continue without embedding any fonts, click
Cancel.
The number of tokens (i.e. licenses to embed a subset) needed to download all
missing fonts from Monotype is put in brackets. If there are more missing fonts
than you have tokens, you have to buy extra tokens first (https://baseline.monotype.com/BuyCredits). For more
information, refer to Fix Missing Fonts dialog: sections and buttons.
Note: If you haven't set up the Monotype Baseline platform, PitStop Pro doesn't know
whether or not the missing fonts are available for download. The
Available for download section will be grayed
out.
After embedding the downloaded fonts, PitStop Pro does not save the
document automatically. Do not forget to save it yourself, if you want to keep
your changes!
