Rotating an object by dragging using the selection handles
To rotate an object by dragging using the selection handles
In the Enfocus Inspector dialog, click the
Select Objects
tool .
Select the object(s) you want to rotate.
Move your pointer near (but outside) one of the
selection handles in the corner of the bounding box, until it becomes a
curved arrow as in the graphic below.
Hold down the left mouse button while dragging the handle to the desired position.
Note: To rotate the object in fixed angles (multiples of the angle point),
hold down the SHIFT key while dragging.
The
selected object is rotated around its center point.
If multiple objects are selected
(as the two text segments in the graphic below), they are all rotated in one go,
around the center point of the selection.
