select the object which you want to move.
You can hold down the SHIFT key and click the left mouse button to select multiple objects.
) key (Macintosh).The pointer changes from
into
Example: Moving the selected object to a new location by dragging.
Example: Holding down the SHIFT key while dragging moves the object along a fixed vertical or horizontal axis.
Example: Holding down the ALT key (Windows) or Option key (Macintosh) while dragging the object creates a copy of the object in its new location.
) key (Macintosh)).
