To change or remove the OPI information of objects
  1. Using the Select Objects tool , select an object in your PDF document for which you want to change the OPI information.
  2. Display the Enfocus Inspector. See Opening the Enfocus Inspector dialog
  3. Click Prepress > OPI to display the OPI information of the selected object.
  4. Do one of the following:
    • To change the OPI information, put your cursor in the File name box, make the required changes and click Change. For example, you may wish to change the file name or path of the image.
    • Select Remove OPI Information from the Actions drop-down menu.
