To remove transparency
  1. Display the Enfocus Inspector. See Opening the Enfocus Inspector dialog
  2. Click Transparency > General .
  3. Go to the page which contains transparent objects and, if necessary, select the transparent object(s).
  4. Click the Actions drop-down menu.
  5. From the Actions drop-down menu, select Remove transparency from page or Remove transparency from selection as required.
    Note: You can also use an Action List or Preflight Profile to remove transparency.
