To change the Layer settings of the selected object
Note: The procedure below describes how to change the settings using the Enfocus Inspector. Alternatively, you can use the context menu of the selected object and choose Assign to layer > <Layer name> (to move it to an existing layer) or Assign to layer > New Layer (to move it to a new layer).
  1. Display the Enfocus Inspector. See Opening the Enfocus Inspector dialog
  2. Select the Prepress category and the Layers subcategory, and click the Actions drop-down menu.
  3. Select Assign to layer to assign the object to the selected layer, removing it from all others
  4. Select a layer from the list, or select New Layer to create a new layer.
