To resample a single image
Using the Select Objects
tool
select a pixel image.
Display the Enfocus Inspector.
See Opening the Enfocus Inspector dialog
Cick the category.
Do one of the following:
- To downsample an image, select Resample above and
specify the threshold resolution in dpi. Only images with a resolution
higher than or equal to this threshold resolution will be
downsampled.
- To resample an image up, click to clear the
Resample
above check box.
Select a resampling (interpolation) method and
specify the resolution (dpi) to which the image should be resampled.
Click Apply.
