To compress a single image
  1. Using the Select Objects tool , select a pixel image.
  2. Display the Enfocus Inspector. See Opening the Enfocus Inspector dialog
  3. Click the Image > Compress category.
  4. Select a compression method: JPEG, JPEG2000 or ZIP.
  5. If you selected JPEG or JPEG2000 compression, select a quality level.
    The higher the quality level, the more detail in the image will be preserved but the larger the size of your PDF file will be.
  6. If necessary, select an ASCII filter.
  7. Click Apply.
