If you create new objects using one of the PitStop Pro tools, you
may want these objects to have specific default attributes. For example, if you type
new text in your PDF document using the Edit Text Line
or Edit
Paragraph
tool, you may want this text to use the font Helvetica, 10 pt. Or, if you create a
new rectangle or a new ellipse, you want these objects to have a specific fill and
stroke color by default.
Proceed as follows:
select text or line art in your PDF document.
