To add a color to the Local color database
  1. Using the Select Objects tool , click any text or object in the PDF document which has the color which you want to add to your User Swatches.
  2. Display the Enfocus Inspector. See Opening the Enfocus Inspector dialog The Enfocus Inspector appears and shows the current color settings of the selected text or object.
  3. If necessary, change the color using the sliders or select another color model (Gray, RGB or CMYK) or spot color.
  4. In the Actions drop-down menu, click Add color to Local color database.
  5. Type a descriptive name for the color in the dialog box, and click OK.
    The specified color is now saved in your color database in the "Local" category, and can be reused later.
