To convert text to outlines
  1. Using the Select Objects or Select Similar Objects tool, select text in your PDF document.
  2. Display the Enfocus Inspector. See Opening the Enfocus Inspector dialog
  3. Click the Text category.
  4. Select Convert text to outline in the Actions drop-down menu.
    Note: You can also use a Global Change or Action List to convert all the text in your PDF document to outlines.
