This topic describes how to edit the page boxes of a particular PDF document using the Enfocus Inspector.
To edit the page boxes in a PDF document
). You can change the lock status of the icon by
clicking it.
appears in the Page Boxes for Page
x box as well.
| Use this option | To |
| Set | Set one page box based on the dimensions and position of another page box, for example: Set crop box to Media Box. This option is only available for page boxes that haven't been defined yet. |
| Set by Detection | Set the trim box and bleed box based on the trim and bleed marks in the PDF document if any. |
| Set Page Box to Selection at | Move the page box you selected in the Page
Boxes for Page x box to the
left/right/bottom/top of a particular selection. If you want to use this option, you must first make a selection using the PitStop Select Object tool. |
| Enlarge Page Box to Selection at | Enlarge the page box you selected in the Page
left/right/bottom/top/all sides of a particular selection.
If you want to use this option, you must first select an object (that is bigger than the selected page box) using the PitStop Select Object tool. For example, if you select an object of 15cm x15cm, and select Enlarge Page Box to Selection At Top Side, the height of the page box will become 15 cm. |
| Apply Design Layout | Apply a selected Design Layout (with page boxes defined) to the current page. If no Design Layout has been selected, this option is grayed out. |
| Show Design Layout Panel | Open the Enfocus Design Layout Panel. You can use this dialog to select and apply a new Design Layout (with page boxes defined) to the current page, or to all pages in the document. |
| Create Design Layout using Current Page Boxes | Create a new Design Layout based on the page boxes defined on the current page. The Enfocus Design Layout Editor is opened and the dimensions of the defined page boxes are already filled out. You can now save or save and immediately activate the new Layout Design. |
| Remove | Remove one of the defined page boxes (but not the media box). |
| Apply page rotation on Current Page | Apply the page rotation defined for the page boxes, but only on the current page. |
| Apply page rotation on All Pages | Apply the page rotation defined for the page boxes, for all pages in the document. |
