Hold down Alt key when dragging a selection area
You can choose what should happen when you hold down the Alt key and drag to select an object:
  1. Bounding outline of your selection, the dotted rectangle is also known as marquee
  2. Object inside the bounding outline
  3. Objects overlapping the bounding outline
