Windows
Sometimes, you want to use a PitStop Pro tool in combination with the Enfocus Inspector. When you select an object, for example, it might be useful to see information about its color in the Enfocus Inspector. Or when you select text, you may want to see its font information. Sometimes it's even necessary to use the Enfocus Inspector, for example to measure the distance between two points.
You can select when the Enfocus Inspector has to appear automatically as soon as you use one of the listed PitStop Pro tools.
You can also choose to rearrange the position and size of the active document window so that it does not overlap with the Inspector, the Processing and the Navigator panels.
