Processing
When you have run an Action List or Preflight Profile, you will probably want to see the result of this action or preflight check. You can select how you wish to see this result:
In the Report Style drop-down menu, you can select a layout style for the report when you view the results in the Preflight Report.
You can use the Enfocus Navigator to browse through the checked, fixed or changed objects in your PDF document, but it also allows you to select a report layout first and then click the Show report button.
